Changing the Pink-i logo to a Black-i
I purchased my Pink-i from TRi tuning. I'm not crazy about the pink color so I changed it to a black-i. I used a cotton cloth and some Goof Off to remove all the pink. It takes a lot of rubbing to remove all the pink. I think this is a better method than using any type of sand paper. You can see how clear the plastic stays by just using a solvent. After all the pink was off I masked the back with some masking tape. Then I used an exact-o knife to cut out around the back of the oval. I just used some light coats black spray paint. For some reason it was impossible for me to get a good shot of the badge after it was black. To remove the OEM badge I just used a dull knife and gently pried it off. It's held in with double sided tape. I used some fresh double sided 3M tape to hold in the Black-i. |
