- Remove the plastic cover which sits ,over the roof to mirror mounting screws , Small screw drive required for this to gently "flip" it off.
- Remove all three of the mounting screws to release the mirror arm from the roof.
- Remove the central screw holding the plastic spacer onto the mirror arm mount.
- Super glue the spacer back onto the arm and quickly refit the central screw , nice and tight but not enough to crack it.
- Refit the mirror back onto the roof mount with the three screws , again quite tight.
- Leave this fully to dry , 24HRs is best.
- Now fully test will a fast motorway drive and you will find the vibration has disappeared and all police cars now become clear.!!!
