2005 Subaru Impreza WRX SL 2.0 Turbo 4x4
€13750
- 121800 miles
- 5 Speed Manual
- No NCT or Tax (Has been off the road since February 2024 will pass again no problems)
- Good Condition Overall always dried stored
- Extremely well minded car serviced every 6000km.
- Front Brembo Brakes (Fitted 2021 with new pads and discs)
- Full 3 Inch Stainless Exhaust
- Apex Lowering Springs
- Xxr 527 with Michelin Tyres
- Plastic Lip Lower Extensions
- TD05 Turbo
- HKS SQV 4 Blow Off Valve
- Turbo Timer
- Short Shifter
- Leather Seats (Few Wear and Tear Marks)
- Pioneer Bluetooth Radio
- Custom Projector Headlights (Could do with New Lens)
- New Excedy Clutch Fitted in 2021 and gearbox and diff oil changed.
- Timing Belt is due as 5 years old
When I bought car in 2020 it got the following
- Front Ball Joint, DropLinks, Inner + Outer Tie Rods, Front Top Shock Mounts, Rear Discs and Pads, Handbrake Shoes, Anti Roll Bar Bushes, New Coolant and Brake Fluid, Gearbox Mount.
Gearbox was stripped and all seals done and any bearings that needed replacing.
Will come with standard exhaust with cat and standard Momo steering wheel.
Will change Oil and Filter for new owner.
Will also come with rear arms with all new bushing and new rear wheel bearings as planned to stripped the rear and freshen up but never got to it, it doesn't need them it was
only to freshen the rear end up with new bushings etc..
€13750
- 121800 miles
- 5 Speed Manual
- TD05 Turbo
- Turbo Timer
- Short Shifter
