22b power
azerp
mate of mine picked up his 22b last friday, we both headed to get it dynoed and mapped today the car is completly stock
got the print out before mapping and its pushing 337hp i thought they were quated at 280hp any explanitions.
What ecu is in the car?
Or did he put a new one in for the mapping?
standard ecu in it want to get a new one fitted and mapped today taht was before the fitting
id say standard there about 320 brake and about 300 torque but in japan they cant advertise them as over 280 bhp
they would have abit more power because there 2.2 l
what was the torque on the rollers?
As Duffman said. Gentlemen agreement. Standard 22B should push out ca 320 PS.
I didn't think the 22b's turbo would go that far!
Which rollers??
Dan
[edit] 22B STi (03/98 – 08/98)
In 1998, Subaru of Japan produced a widebody, 2-door, Impreza called the "22B STi". The 22B was used to commemorate both Subaru's 40th anniversary as well as the 3rd consecutive manufacturer's title for Subaru in the FIA World Rally Championship. On the release of the sales, all 399 sold out from 30 minutes to 48 hours, depending on the report.[5] The cars had the starting VIN code of GC8E2SD. Another 25 were produced for export markets - see the 22B Type UK below.
The 22B had the EJ22 engine as opposed to the regular EJ20 engine. This means the displacement was increased from 1994 cc to 2212 cc. The block is a closed-deck design. The heads (valves, valvetrain and such) were lifted from the STi Version 4 engine. It produce 350 PS (345 hp/257 kW) at 6000 rpm and 363 N·m (267 ft·lbf/37.0 kgf·m) of torque at a lower engine speed of 3200 rpm. The redline was lowered from 8000 rpm to 7000 rpm. The compression is an 8.0:1. The turbocharger is an IHI RHF 5HB (the internal company usage code is VF23).
This car was given a unique color of blue and had fender flared widebody taken from the Peter Stevens designed WRC car, thus widening the width by 80 mm (3.15 inches) for a total of 1,770 mm (69.7). During assembly, a WRX Type R chassis was taken off the line. The fenders were replaced with the 22B STi fenders. The car's curb weight is 1,270 kg (2,800 lb). The suspension is provided by Bilstein. The brakes were standard 4-piston/2-piston brakes. However, the color is red and the Subaru name cast on the brake calipers and painted white. The wheels were increased in size from the standard WRX Type R STi from 16x7" to 17x8.5" BBS Elektra wheels. The car is shod with 235/40 ZR17 Pirelli P Zeros. The clutch was upgraded to a sintered twin clutch with a ceramic disk. The transmission ratios are the same as the standard WRX Type R, but the gears were shot-peened for added reliability. The car has a unique hood, a WRC-inspired front bumper and a unique adjustable rear wing.
The origin of the name 22B has often been debated. Many assume 22 referred to the 2.2 liter displacement and the B was for the Bilstein suspension. This would correlate with the idea that Subaru sells a Legacy Spec B, where the B represents the Bilstein suspension. Others believe that 22B was meant to represent the much recognized 555 decal (555 is a tobacco company that was a major sponsor for Subaru in the WRC) on the WRC car as 22B is a hexadecimal representation of the decimal number, 555.
It must be noted that the 22B STi that is supposed to be #13 was never given the plaque. Subaru of America imported #13 to be used as a press car. Three 22B STis were given the #000 plaque, 2 went to the World Rally car drivers for Subaru at the time Colin McRae and Nicky Grist, with the third going to David Lapworth of Prodrive.[6]
I don't know ..............I too would of said a VF23 wouldn't reach 320/ 340 bhp
well at least it wouldn't be reliable anyway :ponder2: :ponder2:
And I often find reviews like DUFFMAN's post above often differ.
Another point is the 399 sold for Japland would of run on 101 RON octane
and the 25 for Europe would of ran on 97RON , so did they have differen't maps or did SUBARU
just leave the ECU look after it :shock2: :shock2: :shock2: either way it would effect power figures :dontknow:
Niall.
Sure that's only 1.7bar!
The VF22 must be a huge turbo! is it!
Bigger tan a 20g??
Doesn't quite seem right!
Dan
Absolutley not. Correct there Dan. Anybody can push a turbo to its limits for a quick second read out. VF22 similer size to 23/24/28/29 and defo above 330 not possible.
it has a vf 23 turbo and its completley stock he got it back today and it defo was pushing 337 before it was ran twice i will post the dyno sheets for the non belivers
[quote author=azerp link=topic=16301.msg200813#msg200813 date=1247163106]
A dyno is not gospel and has a margin of error of upto +/- 5.0%. But a great way of seeing in or where abouts a cars level is.
so does that mean, that it could be the right figure (337 bhp) either way?
