shadowhearth
ill be servicing my car next week and putting on standart exhaust. what oil would you recomend lads? what thickness do scoobies like most too? Any good place to get online?
everyone here will have a different opinion. for what its worth heres mine any good oil of the correct grade which for our climate is 5w30 will be grand i have always used either mobil 5w30 fully synthetic or castrol 5w30 fully synthetic and i change it every 3000 miles ,my car has big mileage on it and never an issue so i said any good oil and change it regularly WAGON DEC said:you are opening a can of worms maneveryone here will have a different opinion. for what its worth heres mine any good oil of the correct grade which for our climate is 5w30 will be grand i have always used either mobil 5w30 fully synthetic or castrol 5w30 fully synthetic and i change it every 3000 miles ,my car has big mileage on it and never an issue so i said any good oil and change it regularly
popsy b4 said:go to barrys motorsport get urself some millers oil i found it the best out of all oils i used personally i use 10 w 50 in my legacy ,
5 w30 seems a bit light but im no expert
shadowhearth said:popsy b4 said:go to barrys motorsport get urself some millers oil i found it the best out of all oils i used personally i use 10 w 50 in my legacy ,
5w30 comes from factory in imprezas. so far everyone recomended 5w30 too. would love to hear more on that.
shadowhearth said:i am confused now. i found the sticker with info when oil needs to be changed, but it did not said which oil it uses. so which is standart oild for blobk 05 WRX?![]()
[/quote
Impreza came with 10w 40 from the factory and every Subaru garage will use that when servicing.
I would stick with that and go for a good brand, eg mobil1, castrol or motul.
Swrt used to use motul but it's very expensive IMO for a road car.
I use 10w 40 for the road car and 15w 50 for the track car
shadowhearth said:ill be servicing my car next week and putting on standart exhaust. what oil would you recomend lads? what thickness do scoobies like most too? Any good place to get online?
