MY2000 Impreza 413bhp / 420lbs ***PRICE DROP TO SELL*** €15,000
R
Renno555
Guest
€15,500 in current 400bhp spec
The new 2.5 only has a few thousand miles on it and has just been ran in and mapped on a SimTek ECU. The STI 6 Heads are like new. Basically every part that can be changed has been. All the oils and plugs have also just been done.
It wont need to be taxed till Jan 2009.
This engine has 450 + bhp potential and is running A PROVEN 413bhp and 420lbs on 95 ron fuel + booster at the moment. Everything inc water pump , modine, and every gasket has been replaced with all brand new items.
Spec List.
• 2.5 Litre bottom end with forged pistons
• CP Custom Pistons
• Cometic Head Gasket
• ARP Head Studs
• V6 STI Heads
• Supertech one piece inlet valves
• Supertech inconel exhaust valves
• V6 Custom Reversed inlet manifold
• Front Mount Intercooler Kit
• Custom Intercooler Pipe work
• Modified Oil Pump
• Oil Catch Tank
• Uprated Power Enterprise Timing Belt
• PFR7B Plugs
• HKS Dumpvalve
• Tuffnol Inlet Manifold Spacers
• Fuel System
• 740cc Flow Matched injectors
• Parallel Fuel Mod with Modified Rails
• Fuelab Fuel Pressure Regulator Kit Goodridge Hose
• Walbro 255 Fuel Pump
• Engine Management, Intake , Exhaust
SP40 Hybrid Garrett Core Turbo
• Samco 76mm Turbo Inlet Pipe
• Samco Coolant Kit
• Full 3" Exhaust System .
• GT Spec Manifold and Upipe Wraped
• 80mm inlet Ali Trumpet with K&N Cone Filter
• SimTek ECU with Anti-lag and Launch Control
• Apexi 3 Port Boost Solonoid
• Drivetrain
• STI Ver 6 five speed Gearbox + Rear Diff
• Street Performance Exedy Organic Clutch Light weight flywheel
• Chassis
• Eibach Springs
• Whiteline Rear anti roll bar
• Whiteline Rear Drop Links
• Whiteline Anti Lift Kit
• EBC Dics
• Ferodo DS 2500 Pads
• Goodridge braided brake lines
• Motul DOT 5.1 brake fluid
• 17in OZ Superleggera Rims
• Toyo T1-R tyres
• Defi Tripple Gauge Set up
• Forge Header Tank
• Knocklink
€15,500
Re: MY 2000 - 2.5 Litre 400bhp + FOR SALE
savage motor damo cant believe your actually letting it go. :omg:
good luck with the sale i know if i had the money to buy it i would be sending you a pm saying sold. :D
good luck with the sale damo
:thumbsup:
Dont believe your letting her go :omg: after all notes you put into her savage car Damo all the best with the sale :thumbsup:
Re: MY 2000 Impreza FOR SALE NEW SPEC
The spec will be changing to the above in the next while. Ive edited the post.
Damo
Re: MY 2000 Impreza €18500 413bhp / 420lbs
Price reduction for current 400+ bhp spec. Now being sold at €18500 as is. Invoices for all parts etc will be included with the sale.
Damo
Re: MY2000 Impreza 413bhp / 420lbs ***PRICE DROP TO SELL*** €15,500
NOW REDUCED TO 15,500 TO SELL. 413BHP - 420LBS.
Damo
Nice price Damo good look with the sale.
Things are so slow at the moment its unreal.
Yeah hopefully at this price Ill get a buyer for her. Like you ay it is slow lately.
Damo
2000 412 bhp..forged engine..15k. serious bargain
Yeah I reckon it is when you add up what went into the car, its alot more then 15k :omg:
great value at this price................ :shock: :thumbsup: :thumbsup:
good luck with sale..........
Thanks :thumbsup:
Bump
good luck with the sale damo :thumbsup: whats your next car/ project car :ponder:
Thanks mate, not to sure what to do next.
€15000
