That's it tommy, your lucky you don't need to do calipers. On the arches i power washed and sprayed the concept clear off on while washing and used couple small brushes. When i put in the shed i cleaned the arch liners again with the clear off and cloths. Masked all up. Body done with teroson road stone chip east to use and nice finish. The liners are just dressed with auto glym vinyl and rubber dressing. Hub was also done with the teroson. Handy enough. masking prob the biggest bit to do. Calipers were just cleaned up, small bit primer, high temp black 3 light coats, replaced subaru with sticker from ebay (help from hair dryer to put on easier) and 3 coats of heavy duty lacquer.
