that-silver.leggy
hi lads quick question that may be a simple fix but can’t seem to sort. Not sure if i need a bigger cylinder or what?? I recently buy four pots on the front bigger disks and pads etc. i seem to have slight travel on the pedal for the first press then brakes as normal but couple minutes later same thing. I’ve bled the system many times so I’m sure there’s not a trapped bubble of air. Possibly seals ?
