cheers lads i hope it goes well,last 2 times out had some issues with the l/c and then the clutch slipping ill be happy if i can improve on 11.5 run with slipping clutch from last time,triple plate clutch is now fitted and have been running it in since last week,its not a normal drag day so runs are limited so i hope i have enough runs to play around with tyre pressures and different l/c settings hopefully ill find the sweet spot and of course hopefully its dry
