OK if you look closley you'll see
as he enterd the corner he gave the
wheel a little flick.
Normally you would flick the wheel left, hard right, hard on the
accelerator and drift through the corner and as Dave said the
wheels then would be in the right direction.......
But he done the opposite (wheels now pointing at the wall and not the corner)
.............and yes you can do this in a 4wd but and a big but, you need to correct so
that the wheels are pointing in the right direction, if not when the tyres regain traction
you can be in trouble. :shock: :shock:
It also dose look like he lifted off........ not the best time to practice a manover like that when
your approaching a corner at what 80mph ???? maybe more
Niall.
