Its the bulbs in subaru mate alright, at the moment they are standard yellow bulbs with green caps on them so if i could replace them with blue or even blue caps if there is such a thing then i think it would look great
[quote author=keith555 link=topic=17648.msg215845#msg215845 date=1251828128]
Pretty sure it was AndyC who changed his and he got them of ebay cheap enough Rob.
I have 4 bulbs i got off ebay, nearly sure there blue, got them when I was gonna attempt to change the climate control...not gonna bother now, you can have the bulbs if you want mate...no charge.
Jonnie
Sound man jonnie, that'd be great. Hopefully they'll give off enough light to be able to see everything properly. I'll pm you now so i can collect them off you seeing as i'm only down the road
@sweetcakes-isnt it a legacy you have? If your dash is green im assuming you dont have the "blackout dash" like the later ones. I have two of these dashes at home-one auto-one manual-would make a nice upgrade?
Theyre a good bit different on the legacys. Basically you cant really see the dash when the ignition is off due to a heavily tinted plastic screen,then when turn the ignition on the dials light up in sequence,Outer rings-kind of beige colour,then needles-bright red,then all numbers-white. anyway-it looks the sh1t.
Hold your horses, if your gonna change the clocks from the old style to the blackout dials it work work,the wiring loom is different, i sold my blackout clocks to Ianbhp and we tried to fit them but they wouldn't work,they'll connect up alright but they won't light up properly
