[quote author=willyob link=topic=42621.msg488138#msg488138 date=1409506281]
iv heard people saying they boost at 1 bar or 1.5. is a higher bar (psi) not better to boost?
Depends on engine components, intended use, ECU map etc.
One boost value can be great in one scenario and terrible in another scenario.
As a very basic rule of thumb: factory Subaru boost levels are max about 0.9-1.0 bar, a typical "mapped" car would see values of 1.0-1.3 bar.
Values higher than 1.3 bar are seen, but would usually mean it is an engine with a lot of work done like forged internals, uprated studs and much more, as the risk of damage on stock parts is too big at high boost pressures.
BTW 1bar is the average absolute air pressure at sea level. So when you see 1bar boost, it really means 1 bar over relative air pressure, or with other words the pressure in the inlet manifold is approximately 2x the normal air pressure outside.
