Boot leak 1.6 03 impreza bugeye
Shamrock133
Boots getting damp and don't want it getting destroyed as it's in good nick can't find where the waters getting in any tips or fixes
Thx
Hi welcome along worth checking weather strip for cracks damage can remove just be careful clean gutter area after where crap collects I used a product rubber conditioner to keep it supple I had a small rip in mine repaired and refitted wasn't seated properly that solved it for me.
Also worth removing tail lights see if any signs getting in round seal there.
Is there a spoiler on your impreza if so worth looking there too factory seal on boot lid break down round em after years check under spoiler clean inspect when remove too
Good luck
sometimes if they get wet once, itll keep making condensation and itll drip off the boot lid making the carpets wet over and over again. So same as Ciaran said, take it all out and dry it out inside somewhere.
check / change the boot rubber,
If you have someone to get in the boot and watch for water as you run a hose over the boot might show the leak too šŸ˜†
