tomo
Hi lads, would the Brembo brake fluid be ok for a bug wrx with standard 4pots brakes?
The dry boiling point?DERBP ? 260? ?( it is the minimum boiling point of new or unpolluted fluid)
The wet boiling point WERBP ?? 165?C (it is the minimum boiling point of a fluid containing a volume equaling 3.7% of water in the circuit.)
Viscosity = 1400 cSt max
Specifications: SAE J 1704, FMVSS 116, ISO 4925 Class 5
