Brake Pad Part Numbers
Rob Spec C
Where would you go to find a brake pad code? Been to halfords and Proparts with the old pads but they dont know? Would a motor factors be able to match it up against a picture?
If its for your own car the standard 2 pots is MDB1794X. :thumbsup:
Usually any decent Motor factors would match them up in the book for you. When i was changing pads on my GSR thats what i had to do the first time.
EBC red stuff pads for rear code is DP31293C
Black diamond rear pads for 98-00 BD-PP-464,If iam not mistaken they both should be the same for your car too Rob... :thumbsup:
hope that helps... :thumbsup:
Try this website: http://www.camskill.co.uk/products.php?plid=m10b0s1172p0
It has a few part numbers.
Think these are the pad outlines...
Front:
Rear:
Cheers lads, should have said earlier, its for those Wilwood brakes in the for sale section so not the stock 2 pots. I've sent them a mail to see if they will tell me. I am looking to get a set of Ferrodo 2500 for them. they have ferrodo in the rear already but its the fronts that i just cant find
