Rob Spec C
Where is the best place to get pads for a B4? Is there any particular brand I should ask for? Or would the local motor factors be the best place to go and see what they've got. They are standard B4 brakes. R they simple enough to install? Did it on my old car so I assume it is pretty straightforward
Also if any1 knows if the bolt that comes out of the brake disk to attach the wheel is the same as the impreza? And if someone maybe has 1 spare? but i assume they would be cheap enough. Some bumbandit put it back on arseways with a pneumatic gun after he had changed the tyre and it sheared off when i tried to take the wheel off last night to check the pads.
