brembo bleed nipples problem
GORDON GT SERIES II
Club Treasurer
Staff member
As above lads think I'm having bother with the lhf inside bleed nipples it's half seized and weaping some fluid, anyone know someone to do a refurbished adap
Very common issue with brembo calipers. The calliper being alloy and the bleed nepple made of steel make not the best combination. the 2 metals react, corrode and seize in effect.
I sheared 2 nipple threads last time I wanted to bleed the rear brakes, but I fixed them myself by helicoiling the thread in calipers and getting the stainless steel bleed nipples off eBay.
As far as I know Godspeed offers the refurbished ones on exchange basis.
dave what do you mean if possible as in they mightn't be able to be done ?
Sent from my GT-I9505 using Tapatalk
ah ok I don't know how bad it is as it seems to be weaping but the nipple is tight as much as it can go but even when you loosen it it still feels tight as if it's not moving
