brembos on a classic
A96wagon
I have a set off brembos that came off an evo. They look the exact same as a set that comes off an sti so just wondering will the fit if I get a set of discs in 5x100? as in do the bolt up to a V4 wrx or is it a non runner from the start.
I seen a sticky above but the nodes mentioned are different
It's been done by a member on here ,colly .
Bit work involved. Also you'll need 326mm brembo discs I have a couple of sets here if you need
Evo runs smaller discs so some butchery has to be done to the calipers
im prob to new to have pm's
if id get away with them ill take the 50e set, if they badly need a refurb id take a refurb set from you
perfect I go to college out that way this could be a very easy transaction. can I collect weds or Thurs evening?
