Bug eye STI Brembo brakes
M
Matt
Guest
Anybody know if a set of 330mm discs and Brembo 4pot calipers off an STI Bug eye will fit my Type R.
Thanks :thumbsup: :subaru:
Sweet. Thanks Scoobyke.
Found one place sellin them sayin they'll fit any impreza earlier then 05 STI
And another place sayin the discs have 10mm Bolt hole and older iMPREZAS HAVE A 11.4mm bolt hole or something along those lines :thumbsup:
let us know if it works out for ya man... sounds like a good upgrade :thumbsup:
Will do.
My type R has 4pots but Brembos and the extra disc Diameter would be a huge help in stoppin fast :thumbsup:
Ok thanks for the help.
Ill let you know if i manage get them :thumbsup:
Hello Matt,
As the lads said, before & approx 2005 newage the calipers cars will fit to the Type-R :thumbsup:
If you are getting rear calipers, you will have to do a small mod on the back dust plate covers.... its an easy job by all accounts :thumbsup:
Just make sure you have the clearance on the wheels you are running :thumbsup:
Cheers,
Michael
Hi Michael
Its just the front Discs and calipers im hoping to get for the moment until i see a set of rears at a good price.
Should have the clearance on my 17 inch wheels.
Cheers :thumbsup:
Mat not a lot of 17 will clear them if you want to drop over and try your wheels on my car and see if they fit.
I had prop with mine had to get new wheels another 1200 yoyos that i didnt want to spend.
But i have to say worth every penny the classic is lighter then the new age so they are well up for the job.
If you want to try before you buy :dance: you can have a rip in my yoke :thumbsup:
Thanks Keith.
Ive got clearance measurements that im gonna check against my wheels so should be ok.
Just have to find my tape now. Ill give you a shout if im stuck.
Fingers crossed :thumbsup:
