build 93 wrx
scooby93
So I'm at this now. Plans are get engine running smooth. Put front mounted intercooler on it remap it want it running around 300bhp there or there abouts. Some tried to fix an arch that had rust but did a very bad job so not I got to grind most of that out and fix it. New alloys. High spoiler and possibly full respray in blue but there red is nice also just hard to mind. Going to spray the rims gold as there silver now. Il post pics when I get a chance thanks for looking. Also checked under the carpet this evening it's slightly damp and rusted so must take out all the interior and protect it save myself hastle in the future
Good stuff, sounds like your going to do a lot of work to her. Fair play! Great to see them being restored and kept on the road. ????
Yep couldnt let it rot there not found very much so keep them going for as long as we can. Getting the engine running correct is no 1. As u drive is loosing air so it's down on power. So I need to look into it more. The speedo not working may be the cause of it. Must check it after work.
Stay 110% original to maintain value
Not sure on ecu yet. Need to look into it more. May have the engine running full mode now in neutral it's reving to high rev so must take it for a spin and c. Speedo wire isn't in I don't think it hard to get ir in so we're at it. Arch is bad enuf I have it open now can see it needs work so I'm thinking full respray will be getting once I've wat I want got and done.
So wire brushed the arch and them. It.was.getting weak so I. Grinded the piece out and noticed the iner arch was starting to rust. So.need to fix that treat it weld a plate and fill it. Have a welder coming in next few days to look at it.
