Burning rubber smell
Steve H
Active member
Hi lads i just joined the other day just wondering if anyone can shed some light on a burning rubber smell coming from d engine of my be5 legacy its wrecking my head its not constant it smells more when idling after a spin everything seems fine to look at its coming from around the air con compressor area i had a couple of fuel lines changed recently in that area dont know if thats just coincidence as they look perfect
Are you sure it?s rubber??? Could it be your rocker cover gaskets leaking oil on to manifold??? Very common, and is usually noticed when sitting in traffic
