only a hook to remove old rubber seal and a bit of 1000grit sandpaper - push the piston out, check if the piston has rough edges, if it does, take the sandpaper and even it out so the surface is smooth - dont use too gritty sandpaper, as you may create more uneven surface
After that replace the inner seal, and push piston back in.
