Changing plugs
evoman
How hard is it to change the plugs on a B4 leggy. Any specialist tools needed? Any help appreciated.
Very easy done from the top.
Tools needed , 16mm plug socket, 3/8" short extension (with wobble head it helps for removing the ratchet)
I remove the air filter housing and washer bottle to make life easier and use tools baz listed
Cheers for the replies lads what kinda of a time line would ye put on doing the job hrs? days? weeks?
Graham
2/3 hours would give you loads of time for everything Probley do it in less that an hour after the first time :thumbsup:
