Wastegate chatter myth
There is a common myth in the automotive world about so called "wastegate chatter" or "turbo flutter", a noise created on lifting off the throttle in a turbocharged car. The sound is commonly described as a chipmunk or a rattlesnake and is often stated incorrectly as being a result of the turbo's wastegate closing.
The noise is in fact the air compressed by the turbo passing back through the compressor wheel of the turbo after the airflow is abruptly halted by the throttle plate closing. However, in some cases, i.e. where it doesn't open fast enough or is set up to only react to high boost, some chatter will remain. Surge can occur on diesels when the turbo is attempting to pressurize the air at a higher pressure ratio than the compressor wheel can flow at a given speed. Diesels have no use for a Blow off Valve as they do not have a throttle.
The chatter noise is very noticeable on WRC Rally cars, where no blow off valve is allowed.
