Classic Air Idle Valve - code 24
I had mine throw a code intermittently - usually when coasting off the throttle. Pulled and cleaned it - no change - turned out that it was actually my neutral position sensor on the gearbox that was the problem. Wire had snapped, car thought it was in neutral all the time and apparently it throws the IACV code
Will have a look! Thanks
