Hi All,
The diff in my Type R is clunking/binding when taking tight corners/reversing etc.
When I scroll from open to locked it doesn't make any difference. The dash lights work perfectly
I'm running millers lsd oil in the diff and millers in the box.
It seemed fine when I first got the car, if maybe a very faint clunk. The car was stripped underneath and reassembled and since then I've had the problem.
I noticed the drivers side shaft was longer so I swapped it over, which made no difference and swapped it back, I later read that the driver side is longer anyway.
I did notice that not much force was need to push the shafts into the diff and the C-clips were missing, now if there in the diff itself I'm not sure, its something I may have to check this weekend. But would they make any difference?
There doesn't seem to be any loose wires at a glance.
I'm also wondering if there was an additive put into the old oil which was drained off.
