@DonTommy: you have a valid point there... and not one that came immediately to mind when I answered yesterday. There could well be a significant difference in circumference (over 1%). Of course there is no calculator on line to tell you the percentage difference in circumference as it would differ between different tyre makes/modes. The reason for this is because tyre shape deformation is hugely dependent on tyre construction and inflation pressure (side-wall stiffness/support, running surface shape, compound).
Personally I would never put the size tyres mentioned on rims that wide. 9" is the max width for the tyre size indicated by the OP and already not recommended... and 9.5" is just too wide for that tyre size to be safe. It will adversely affect handling and if anything happens you will not be insured, it will cause issues at NCT time, plus it only takes one Gard who half knows his/her stuff to stop you.
CLICK HERE for a link that has a handy table in it giving min-max tyre width to wheel width index (half way on page).
In general though... if say changing from a 17" rim which is 7-8" wide running 225/45/17 tyres, to an 18" rim which is 8.5" wide running 18/40/225 - and you put the same on all 4 corners is fine as all 4 will rotate at similar speeds.
Here's a link to another calculator to see the difference in circumference between tyre sizes to help choose correct size when saying going up a rim size.
It will give you an idea of rotational circumference changes with different wheel/tyre combos; however, it doesn't allow for circumference distortion due to different wheel width front/back as per DonTommy's point (which will easily be 1cm). Now on new tyres that difference you'd get away with that as
<1%, but as the tyres wear you could end up with 1.5-2% difference... and that could be too much for diffs and abs.
