Do I need This Washer? -Pic Inside
pugtk
Do I need this brake washer with tabs for the rear 2 pot brakes?
Can I just use a normal washer without the tabs?
I presume the 2 tabs are just to stop it turning so I can't see why you can't use a standard washer
Washer shape
That washer just isnt a washer with 2 tabs,its a specific shape to sit your slider pin onto your caliper at correct position,to be honest would be replacing with same type off washer,they cant be expensive,im sure somebody has old callipers around with that type off washer if you cant find new ones on e-bay.
Just my thoughts JOCK.
