Any ideas how to remove one on wrx. Think the motor that winds up da window is acting up. Think the after market alarm that was fitted had new motor fitted so windows go up when alarm is switched on
unscrew the screws in the door handle inside the door, take out the switch gear and just pull it off, they just pop out and pop in, just dont loose any of the doofors . . .
Screw in the door reless handle, and two in the handle of the door then just pull off fron the bottom workig your way up and left off the window recess.
