More than likely the motor remove the door card and give it a tap and see if it makes any noise . While in there check theres power at the motor when pressing the switch will rule it out
Have msgd ollie to see if he has one.
Fingers crossed. It's a black bag jobbie for the week while it sits up.
I'll pull the motor later try clean it. Thanks
Regulator and motor assembly right front door glass for Subaru Forester SG 2002-2008 OEM numbers 61188SA000 / 61188SA001 / 61222SA000 / 61222SA001 / 61222SA002.
