Dump Valve or waste gate b4
Phil-b4
first which is better?
and what make etc is the best one heard hsk is the only one that will properly work
thanks!
phil
[quote author=Phil-b4 link=topic=30643.msg354270#msg354270 date=1306347778]
thanks!
phil
Waste gate is completely different to a dump valve, wastegate regulates boost pressure and is usually found in the turbine housing on a turbo. A dump valve is on the boost pipework between the compressor outlet and throttle body, usually found on the intercooler on subarus.
Its a dumpvalve you want for the noise is it?
wouldnt mind a bit of extra performance but kinda want the noise.
which make is better
its the twin turbo
aftermarket BOV is a big no no on twin turbo's from what i heard. i went back to standard BOV on mine recently, car is so much smoother!
[quote author=Sweetcakes link=topic=30643.msg354313#msg354313 date=1306361779]
Forge dump valve sounds much better than the tweet from the HKS imo
Yeah agree or you can chance the cap on the hks
