scooby1wrx
Failed tonight not bad doe, will need a retest, i left it late in the day to try change my downpipe,
but it didnt go as it might have, test at eight, and seven ive just relised the cated down pipe wont fit past the
H brace and its awkward to get to one bolt as the wishbone gets in the way, so for anyone trying it, if you have a
H brace bear that in mind, also a good idea to get new gaskets beforehand center section and turbo, i didnt get antin done for the
test apart from getting scoobymaniac to strip my mirrors and elimenatethe freeplay witch he failed on, mine were flapping and moving too much,
took a bit of work to sort but like new now, i failed on headlights too high, emmisions, and a torn cv boot, witch i already have
and i have asked and on the retest they only check the tings you failed on so if you put cat on first time you dont need it second time
Have to say thanks to phil, would have missed my test if not for the help, karma for that.
