Front Splitter fix
Markokavo
Broke my splitter at track day and want to fix it.
Seems to be a clean break.
Pu plastic splitter.
Have been thinking of a few ways to fix it,
but want to know what way is the best.
I'm sure some of you lads have tried this so any advice appreciated :thumbsup:
Or is it worth the hassle and just bin job. :icon_cry:
put miter mate on it at the break it will be set in 10 seconds and fit the rest of it back on :thumbsup: worth a try anyway . hot laps in mondello are always on the edge :thumbsup:
I've fixed more than my fare share of splitters and they are never right again . I just binned my last one . Not worth the hassle imo
I fcukin mangled mine without a clean break last time.
Got a lad to carbon wrap it back into place and you wouldn't even know the difference.
Cost around 100 to do it but he did a great job and used very good wrap.
It's stronger now than ever before due to the wrap.
Re: Front Splitter
We can plastic weld most common types of plastic,once stamped on the rear and we have a matching rod.Failing that,we can magic staple it across the crack then glue and finish.it Either method is 100 percent perfect and as strong as ever.Most body shops have this gear.
