geogan
Can someone tell me what bore / wall thickness vacuum tube is correct for STI and also if the straight hose below is suitable for fuel lines to fuel pressure regulator?
Vacuum Tubing available in 3x2mm,4x2mm,5x2.5mm,6.3x2.5mm,8x3mm + 10x3mm bore x wall thickness
http://www.murraymotorsport.ie/products/samco-vacuum-tubing
http://www.murraymotorsport.ie/products/samco-straight-hose-1-mtr-length
I need to reposition the Tomei fuel regulator which had pressure gauge fitted and the 3-port wastegate turbo solenoid (which JGM temporarily fitted) into permanent positions in bay.
We couldn't do it because the original fuel/vacuum lines were too short to reposition them.
Thanks
Thanks
