Gauge FAQ: Read if you are thinking of buying some!
scoobycolm
Wish I read this before I bought crap Gauges for the old car :facepalm:
Gauge FAQ
Who are the major gauge manufacturers?
www.omoriusa.com
www.prosportgauges.com
www.autometer.com
www.nippon-seiki.co.jp (Defi and STi Genome manufacturer)
www.daddysscp.com
www.greddy.com
www.autometer.com
www.meganracing.com
www.blitz-performance.com
www.apexi-usa.com
www.hksusa.com
www.vdo.com
www.stri-racing.com
www.stewartwarner.com
www.aempower.com
Lamco (Subaru OEM manfucturer) does not have a website
Please note that there are more gauge manufacturers and this listing contains only the most talked about gauges on NASIOC.
Who makes the best gauges? There is no best gauge manufacturer. Times change, but currently and historically the most popular manufacturers are Autometer, Defi, STi Genome, Prosport, Omori, and MadDad.
What gauges should I have? That is the question of the century with no real answer. We will discuss the following theories though:
On an unmodified vehicle no gauges are needed. This is a fairly safe statement. If more gauges were truly needed, they would be supplied by the factory as original equipment. If one would like to argue this point, you are more than welcome to argue this with SOA or Fuji Heavy Industries to your heart’s content.
For a turbocharged car, the must have gauge is the turbo boost. For a singular mounting, the OEM position of on the steering column is considered the easiest and most discrete location. Why this gauge? Even on an unmodified vehicle, there have been discoveries by owners who have installed this gauge that they are not seeing stock target boost levels. The only way to see if your car is hitting target boost is through this gauge. While there is no danger in less boost, most would want at least the OEM target levels thank you very much.
What three gauges? This is generally the #1 gauge question due to the popular A pillar gauge pod or the factory clock gauge pod that hold three gauges. The correct answer is there is no correct answer, but the most popularly used gauges are: Boost, Exhaust Gas Temperature (EGT), and Oil Pressure.
Why these three?
Boost: 100% of engine management systems including the stock one have target boost levels. The only way of ensuring you meet and not exceed these levels is with this gauge. It is considered by most to be the #1 gauge for function and ease of installation. The boost is read off of a tap in the bypass valve line and no other location.
EGT: Monitors your exhaust temperature. This gives you a relative indication of A/F ratio and knock/detonation threshold. When used correctly, this can give you can indication when its time to back off of aggressive driving. Mind you, this gauge is not to be considered an A/F or detonation monitoring device as there is no direct means of conversion. EGT should be measured via tapping into the #4 runner of the exhaust manifold and no other location.
Oil Pressure: The main consideration for oil in a motor is a loss of oil, of which this gauge gives you a relative indication. Yes, oil can be too hot or cold, but neither condition will lock up your motor; loss of oil can. Mind you, this gauge is not to be a replacement for checking your oil level as pressure does not equate to oil level on a one for one basis. Oil pressure may be read from either a gallery plug or a sandwich adapter.
What are the other gauges available or to consider?
Clock: Yes, a clock. Since the OEM clock is often deleted due a dash housing that replaces it, a clock gauge is an option for replacement.
Coolant Temperature: Yes, there is an OEM idiot gauge for this function, but the OEM unit is designed to be heavily dampened which leads to sluggish movement and slow response. They also only supply a general indication. This means that when you notice you are hot, you have no idea exactly how hot your car is or how long it took to get to that state. Aftermarket units tell you the exact temperature and many gauges feature warning lights or buzzers set by the end user as a true warning. Keep in mind that temperature probe placement plays a role as a probe placed after the thermostat will only see correct coolant temperatures after the approximate 15 minutes it takes for the thermostat to open and coolant to fully flow within the system.
Oil Temperature: Why is this important? Oil has a sweet spot. Oil works best over a narrow temperature range of 220º to 260º F. Above 285º F motor oiloxidizes and begins to turn to varnish. Below 220º F, oil is too cool to boil off trapped/suspended water and excess fuel. Another rule of thumb is that oil temps should be about 50 to 60º F hotter than coolant temperatures. This is why the generally preferred method of cooling oil is to employ an oil to coolant heat exchanger because it has the added benefit of warming the oil when cold.
Fuel Pressure: Shows how much fuel pressure is headed towards your stock or aftermarket fuel rails. This is critical for people who have an adjustable or modified fuel pressure regulator.
Voltage: Shows you the voltage your electrical system is producing.
Air/Fuel Ratio: We have two types here that need discussion.
A true A/F ratio gauge is used with a dedicated wideband oxygen sensor to provide A/F ratio data for tuning purposes. This gauge provides tuning support via quantitative A/F data. These are generally sold as sensor/gauge packages in the neighborhood of $300. Wideband systems are sometimes called"UEGO" for Universal Exhaust Gas Oxygen. The purpose behind this unit is to accurately determine the ratio of air vs. fuel. The reason this is important is for tuning purposes as a leaner mixture, to a point, creates more power than a richer mixture. Various tuners use various proportions though as this is not a how to guide on tuning. Its basic purpose is to allow the tuner to ensure the mixture is neither too rich nor too lean as both cause issues with EGT and/or detonation.
The other type is a unit designed to be wired into the factory oxygen sensor. The factory oxygen sensor is not a wideband unit that can be used for tuning. An A/F gauge that is wired into the factory sensor provides pretty lights that are 100% meaningless to air, fuel, or how much change is in your ashtray. So, if you have an empty slot in your three gauge unit that you would like filled, go for the clock gauge as it actually has a function and purpose. Seriously, this is a useless gauge.
What type of gauge should I get, mechanical or electrical?
Mechanical Gauges:
Mechanical gauges do not require power to operate.
They can use power for lighting purposes though.
They make direct physical contact with the item they are reading.
Mechanical gauges can have noise to them. Some might have a slight rattle as there are moveable gears, pins, or pivot points inside which may cause noise.
Can have a jumpy or have an erratic sweep.
Generally less expensive.
Electrical Gauges:
No large connectors and tubing coming out the back.
Can be mounted in more unusual positions without connections showing.
Easier to install in tight areas.
Easier to install a great distance from the item being measured.
Stops fluids from entering the passenger compartment.
The pointer sweep is more smooth and seamless.
Generally more expensive.
Which is more accurate though? For 99% of users either will work just fine. In theory, there is a slight advantage towards mechanical gauges, but recent electronic advances have narrowed the accuracy to the point where it is really a moot issue.
Any gauge dangers? Under no circumstances should you use a mechanical gauge inside your passenger compartment that measures flammable fluids such as oil or fuel. Boost is 100% fine, but anything with fluids just doesn’t make sense.
Where do I mount my gauges? That depends on you. There are many solutions for the different size and type gauges, some out in the open, some stealthier than others. The popular mounting solutions are A pillar mount, steering column mount, speedometer bezel mount, clock mount, left hand driver’s A/C duct mount, glove box mount, vent mount, and of course, custom mounting. Most mounting options require some arts and crafts skills to get to fit right though. This means that you may need to perform some sanding, double sided taping, dremeling, or other slight handyman actions in order to achieve a perfect fit.
This is an example of excessive, compulsive gauge madness. The good thing about it, is that it shows every major gauge mounting area except for the single steering column mount, the glove box mount below, and the vent mount below that.
How do I convert BAR or PSI to whatever? Unit measurement is very important and should be given due consideration when gauge shopping. While having a quality JDM gauge may make you the cool kid on the block, the BAR to PSI conversion can drive you nuts. Hence the popularity of people switching from the perfectly good stock Lamco boost gauge that reads in mPa to an aftermarket PSI reading unit. The easiest way to convert these figures is to (for example) type 14.7 PSI into BAR in www.google.com and let it do the conversion for you with its built in conversion ability.
What about making my gauges dimmable? The links of interest below has some tips. It is also worth mentioning that the Subaru dimming circuit is non-standard since it is fixed positive/variable negative. Most electrical gauges are wired for the opposite, fixed negative/variable positive. This can cause problems if they are connected to the car's dimming circuit. Such gauges that share a ground for measurement and lighting must NOT be connected to the variable illumination wiring. To install such gauges so that they dim, an additional circuit is needed to "flip" the polarity of the illumination to the gauge.
What gauges match my OEM color scheme? Several manufacturers make gauges to mimic the WRX or STI color scheme, you'll have to search which manufacturers make gauges that match your interior. As well, some offer end user color adjustability that are worthy of looking into. There are ways to modify gauges to color match via new bulb condoms or by using a colored marker as well, though that takes some modification and research and is not everyone's idea of the correct way to get the gauges to look right. For really color particular people, this thread shows you how to mod your existing OEMcomponents for a 100% identical color match.
What about senders? A sender is the term for the device that actually measures the output you are looking to monitor and sends the information to thegauge face. Not all senders are created equal. Top grade senders are sometimes referred to as "VDO style" and have 2 terminals on the top for a separate and true ground. The insides are also constructed different with higher quality material and tighter tolerances. Most senders are matched to the gauge. So XXX gauges should use XXX senders. You can use a sender from a different manufacturer and it will work, but the chances that the resistance curve is the exact same is slim, in this case, the gauge will be off by varying degrees.
BSP, NPT….what does all this crap mean? British Standard Pipe Thread and National Pipe Thread. BSP is the European standard, while American stuff runs on NPT. These are terms for pipe thread types and pitch. They can be complicated, especially since they are close in sizing so that you can easily confuse a tight fitting thread with the wrong pitch thread. If you need adapters of any kind, McMaster-Carr is considered the source.
What about the famous gallery plug? It is located on the aft portion of your motor, towards the passenger side, under the intercooler. It is a half dollar sized round plug with a 5/16" female hex head. The thread size once your remove the gallery plug is 1/8 BSP. This is a common location for oil pressure or oil temperature senders.
What the heck is a sandwich adapter? It is a machined aluminum piece that goes in between your block and oil filter. It is pre-tapped to allow you to run oil pressure and oil temperature senders into it.
Which is better for my sender, gallery plug or sandwich adapter? Either works fine, though in the end the sandwich adapter is generally easier.
When I start using senders, adapters, etc., what do I use to seal it up? Three Bond 1215 or similar silicone based gasket maker, though some have used teflon tape or anti-sieze compound as substitutes.
Can I replace my OEM boost gauge but keep its look/location? Yes. Due to the unusual mPa reading of the Lamco gauge, it is a quite popular swapout. In order to do so, many will replace it with a slightly larger unit and use the same housing. Grease for lubricant and a hair dryer to soften the housing are all that are required to install an aftermarket unit as they are usually just 3mm larger than the stock gauge. It take some work to get the new unit in there correctly, but it can be done.
What are the normal gauge readings? The below listed readings are for a stock vehicle. Built motors, tuning through engine management, etc. can change these readings. As well, your gauge manufacturer, sender manufacturer, sender location, etc. can affect these readings. The best advice if your readings vary from the “norms” listed is to track your readings to find out your specific readings and record them to show cold, normal, regular, hot, high, etc. Once you have plotted your specific norms, then you can rely on them to spot problems.
Boost: 15.9 PSI max 2015+ WRX, 13.3 PSI max 2009-2014 WRX, 11.9 PSI max 2008 WRX, 11.6 PSI max 2006/2007 WRX, 13.5 PSI max 2001-2005 WRX, 14.5 PSI max STi.
Oil Pressure: 100 PSI cold, 20-40 PSI normal.
Oil Temperature: Cold = outside temperature, 220º to 260º F normal
Coolant Temperature: Cold = outside temperature, 170-200º F normal.
Fuel Pressure: 30-48 PSI normal.
EGT: 1400º F normal cruising, 1600º F during spirited runs
What about odd-ball gauge like devices? Those are entering the market at an astonishing rate these days. The main ones to come on the scene are the OBDII based units, the most famous of which being the PSI3 unit. Other units, though too numerous to mention, include the COBB AccessPORT ver. 2 with its gauge feature, TurboXS DTEC system, the Defi HUD unit, and the HKS CAMP system. We can also lump one-off units like Knock lights, the Scanmaster 4 channel EGT set-up, etc. into this category. While many of these units are worthy of consideration, this FAQ does not detail every single unique “gauge-like product” on the market though the more popular ones are listed via this question.
Links of interest:
Pics thread for gauge installs
Boost gauge install
Boost gauge install
Boost & A/F install
Oil pressure gallery plug
Oil pressure
Oil pressure sender
Oil pressure
oil pressure
Oil temp
sandwich adapter
OEM 3 gauge pod
EGT
EGT probe install
Dimming gauges
Dimming gauges
Misc gauge installation help
Gauge wiring, coloring, dimming
Editors Note
My thanks to Glenn from www.prosportgauges.com, Rich from www.daddysscp.com, and Dan from www.fastwrx.com for their input that provided a lot of the information contained within this FAQ.
This post was created because I wasn't able to find a good gauge FAQ. I came up with the text based on LOTS of searching here. Upon reading this you should have an idea of which gauges best suit your needs or not. The manufacturer is up to you.
If you find an error in this FAQ, please PM me with factual details and I will update this post. Responses such as, "I have XXX's gauge and it's great!" or "XXX's gauge broke after 1 month" are not appreciated here, that is what the Car Parts Review Forum is for.
Source -
http://forums.nasioc.com/forums/showthread.php?t=1193843
Jeazus Coln ur gone mad with the posting recently ????
Great to see quality posts like this ????
Great find keep up the good posting
Yeah havent posted anything in ages so just trying to add a bit that will be usefull for members :thumb:
Perhaps sometime you could add a bit in this thread about using softa gauges and the torq app
I know some already use it but it may be of use to some members :thumb:
Sure can do mate ????
It's Colm that put me onto the soft gauge setup he picked me up a Odb 2 Bluetooth device that plugs into the Digasnostic port under the steering wheel. I beleve Odb2 is used by pretty much all cars since 2008 except Vw group cars.
Obd2 device Bought for about 15 euro.
The app I use is called Toqure Pro there's a free version but the pro version is only 3.50 and has a huge amount of features that the free version dosent.
Install (I uses android think same is available for iPhone but unsure)
Main screen looks like this
Comes with a default set gauges and layout that can be customised dial type changed backgrounds changed I run a Lamco 1.5 bar Gauge and the Torque app reads exactly as the lamco dose.
U can customise till ur hearts content
Only thing I want it to do that it's not yet is Oil Tem there's a custom Pid (equation) that can added to get this working but when I added it still dosent work.
App can scan for faults and if if has a fault logged it will show up then fault explanation can be gotten by taping on fault and root problem can be traced, saved or cleared ect very handy tool.
The avg mpg instant and distance to empty is intresting to look at when not driving on.
Hp at wheels and boost gauge very useful.
All the dials can have min and max values set (can be set up to mimic lamco boost gauge ect) and alarms (for when a threshold is reached) ie when certain revs is reached ect ect
Defo a worthwhile edition to the car
https://youtu.be/vQSsUPrGLHs
Good Man Ciaran :thumb:
Torq is only available for android phones
there are iPhone equivalents like DashCommand
also if you purchase a obd reader to use with your app just be careful
Bluetooth obd2 adapters for android phones
and wifi obd2 adapters for iPhones
as there are 2 different types
they are readily available on adverts.ie , e bay , amazon and other similar sites :thumb:
That's a handy bit of kit ciaran
Just ordered one handy for the fiesta as my petrol gauge is fucked
Handy bit of kit alright however
you tell the app how full the car is in set up ie when u fill it u ajust it accordingly and tell app car is full ie in vehicle settings and it works away after that..
See below..
But lots of info to digest and u can take it out stick it into the WR1 [emoji106]
As Torque doesent work for Iphones / Ipads Here is a app for users who want to connect with there car
It is also available on android and laptops :thumb:
DashCommand
DashCommand™ is loaded with features, including a skid pad, race track, virtual dashboards (using our patent-pending DashXL™ technology), inclinometer, and OBD-II data logging & diagnostics (find out why your check-engine light is on). Using WiFi technology and a supported hardware interface, you will be able to connect your iPhone to your OBD-II compliant vehicle and monitor, log, and playback vehicle information and parameters (skid pad, race track, and inclinometer features are fully functional even without an OBD-II connection).
Please see the hardware page for more information on supported devices and OBD-II interfaces.
DashCommand™ supports all OBD-II and EOBD compliant vehicles whether they be US, Asian, or European.
Supports all OBD-II protocols: SAE-J1850 (PWM and VPW), ISO-9141, ISO-14230 (KWP2000), and ISO-15765 (CAN).
Visit our user forum for discussion and information about DashCommand™, product features, and new releases.
*1996 is the year the OBD-II system was standardized for passenger vehicles sold in the United States. In Europe, this was standardized in 2001 for gasoline vehicles and 2004 for diesel passenger cars. Please verify that your vehicle is OBD compliant before purchasing.
Awards and Recognition
DashCommand™ was selected by an international journalist from over 2000 new style and performance products to receive a SEMA 2008 Global Media Award! It also received an editors choice award from DSPORT magazine as one of the Top 20 New Products of SEMA! It was voted one of the best deals for under $300 by Truckin' magazine! And a 2008 SEMA Show Top Pick by SportsCar magazine!
DashCommand™ Features
Virtual Dashboards
High quality dashboards utilizing our patent-pending DashXL™ technology. DashCommand™ comes with pre-loaded dashboard skins for both portrait and landscape modes. The DashXL™ skin sets include multiple dashboards with buttons to navigate between them. Each dashboard features a different gauge layout, so you can choose the right one for you.
These dashboards are built using our DashXL™ editor (accessible from the Tools menu of any of our freely downloadable Windows software applications). Using the DashXL™ editor, you can design custom dashboard layouts, so you can make them look just the way you want (and even share them with your friends)!
Skid Pad
Professional skidpad showing real-time lateral, acceleration, and braking G forces. Clearly marked G-force circle visually plots the G forces and keeps a record that you can instantly understand. It also features indicators showing your maximum left, right, acceleration, and braking G forces.
Race Track
Visually maps out your path as you drive around the race track. Displays your current location and whether you are accelerating or braking in clear and easy to see colors. Visually analyze different race track laps to see how acceleration and braking changed from lap to lap.
Inclinometer
Do you like to go off-roading or rock crawling? The inclinometer functions as both a tilt meter and a slope meter. Give yourself a little more confidence when off road, showing the roll and pitch attitude of your vehicle. Handy in terrain where the horizon is not horizontal or when wheeling at night and you can't get a good visual reference. Easily toggle between two different modes of display.
Other Features
  • Full support for OBD-II diagnostics
  • Find out why your check-engine light is on
  • Read and clear diagnostics trouble codes (DTCs)
  • Supports over 220 OBD-II parameters
  • Display sensor data directly from the factory computer in your vehicle
  • Record and playback log files showing OBD-II data and also skidpad/race track data simultaneously
  • Vehicle manager helps you keep track of different vehicles and log files automatically
https://www.youtube.com/watch?v=HCsVYmIgMeQ
Source - http://www.palmerperformance.com/products/dashcommand/iphone/index.php
From reading up a bit further
It looks like Jdm Cars and older european models produced before 2001
are not OBD-II compliant
so you need to do something different for these cars
If anybody can confirm yay or nay or who has tried this with there car please let us know
But it looks like they are on the SSM protocool
And only one adaptor will work for these cars
so not the ones you see on usual sites
It looks like you only buy this one OBDKey http://www.obdkey.com/vehiclediagnostics.asp
Here is some info from there website regarding Subaru and SSM
OBDKey Support for Subaru Cars
Special support page for Subaru cars. In progress through May 2014.
This support page will cover the SSM support over K line and CAN bus for Subaru cars using OBDKey. Feedback is welcomed via OBDKey Support.
OBDKey was updated with Subaru SSM protocol support in 2010 using the 4800 baud rate serial data communications on the K-Line (OBD J1962 pin 7) interface.
Many early Subarus are not OBD-II compliant as they have been built before the US requirements date of 1996, or the European requirements date of 2001 or because they were launched in markets that did not require OBD-II compliance, like Australia, Japan and the rest of Asia.
In these cars there is still an OBD-II style socket but OBD-II is not supported. However, there is a protocol unique to Subarus called SSM which OBDKey can use in these cars.
Additionally, in OBD-II compliant Subarus OBDKey can take advantage of the car's support for both OBD-II for diagnostics and SSM for data acquisition.
Later, Subaru cars switched to using the CAN bus based protocol for OBD-II diagnostics. This came in about 2008 (to be verified) and has much faster data access.
In the later cars the original SSM protocol over K line was dropped and SSM over CAN bus was introduced.
OBDKey Developments - May 2014
During May 2014 the OBDKey Fault Code Reader for Android and Windows is to be enhanced with reading and clearing fault codes from the engine ECU using the Subaru SSM protocol.
OBDKey Fault Code Reader for Android Showing Reading of Engine Fault Codes from the Subaru engine using the SSM (over K Line) protocol.OBDKey Subaru Support Downloads, Videos and Documents
Downloads
OBDKey Subaru SSM Configuration Utility​
Windows software application for configuring the OBDKey unit as either a standard OBD-II interface or for the Subaru (SSM) mode interface.
Run the application and open the serial (COM) port for OBDKey. Then choose the "Switch to OBD-II" option for normal OBD-II operations.
You will need to run this and switch the OBDKey unit to SSM mode before running an SSM application like EcuExplorer, then run it again and switch the OBDKey unit to OBD-II mode before using standard OBD-II software.
Download OBDKeySubaruSSMConfigurationUtility1pt10
OBDKey Fault Code Reader For Windows - Version 1.48 with Subaru SSM (over K line) support added.​
Videos
OBDKey Fault Code Reader - Windows 8 Subaru WRX Engine, OBD-II Protocol
https://www.youtube.com/watch?v=xmC7-KNkmWk
OBDKey Fault Code Reader - Android Subaru WRX Engine, OBD-II Protocol
https://www.youtube.com/watch?v=lclm_UABLtU
OBDKey Android Torque Tutorial
https://www.youtube.com/watch?v=qNdJ8rhhpYE
Documents
User Guide for using OBDKey with the Subaru SSM protocol and Torque for Android (PDF - 998KBytes)
