I bought new gearbox and was advised by the guy from 22b.com site to run on this Redline oil, which is designed for heavily loaded racing diffs and gearboxes.
As my type-R gearbox has gone recently I consider to use it in the new one.
The gear change for the first 10 minutes while the gearbox is cold may be a bit rough and heavy but... if it helps?
[quote author=Codders link=topic=12682.msg193818#msg193818 date=1244807997]
Does that not mean then you'll have higher wear in the first few mins?
