H
http90
Guest
[size=15pt]GRE PSR255 50 Channel Scanner[/size]
Pretty good Scanner Many a rally it was on
But using it less and less !! So May be of use to some one. Also have a magnetic antenna which can be roof mounted and attached to the unit -> does give it slightly better range
[size=13pt]Spec :[/size]
10-Key direct frequency entry
Duplicate channel program warning (LCD)
Manual channel proceeding
10 preprogrammed band search
Rotary volume and squelch controls
3.5 mm ex-speaker jacks
Separate POWER and CHRG jacks
BNC antenna connector
Reset switch in case of lock up
Channel lock out to increase effective scan speed
2-second scan delay On/Off
One temporary monitor channel
LCD back light On/Off
Direct search from any mode
Key tone for acknowledgement
Key-Lock for safety
Crystal filter for 1st IF and Ceramic filter for 2nd IF
The PSR-255s features include 50 memory channels, 10-key direct frequency entry, 10 Pre-programmed search bands covering all popular bands including CB, VHF Hi/Lo Bands, and UHF.
[size=17pt]e100[/size]
Key-Lock for safety
