head gaskets for ej206
nehcra
Hi guys, can anyone tell me if a head gasket set for an ej20 engine will fit on a 01 Jap import legacy Twin Turbo 2.0 engine code ej206? I got this part number from a Subaru dealer 11044AA483 x 2, but I also looked online and found part numbers: 11044AA482 11044AA463 11044-AA463 from this website http://importcarparts.co.uk/parts.asp?cat=96&sub=2857&sec=2874&var=54&dc=y
Just wondering if this part: http://importcarparts.co.uk/parts_info.asp?id=66&cat=96&sub=97&sec=143&var=68&dc=y&gen=&searchKey=
is the same?
Thanks
If you give them lads a ring, they should be able to sort you out with the right one. I was in a similar situation getting a timing belt kit last year and they knew exactly what i needed once i had chassis and engine numbers :thumbsup:
