Gents,
I recently upgraded my brake setup on my WRX to brembo's. I bought a set of used front discs from a member on here which looked like new and a full set of calipers from the UK. It took me a while to get everything together but its finally all fitted. New pads front and rear. New discs on the rear as well (Godspeed, Kevlar)as fluid and I checked the pistons were all working. No issue bleeding after fitting either.And the wheels are all balanced.
Here is the deal. I have no problem braking at low speeds but anything over 100kish theres a wobble in the stearing. If i brake gently it is less pronounced and as the car slows it reduces back to normal. Its the same hot or cold.If anything its slightly better when hot.
I was thinking its the discs or rather I hope its just the discs. Is there anywhere around Westmeath area i could get them checked or do I just get them skimmed anyway?I would rather buy new discs if the cost of skimming is high and may not be the problem.
I use the car every day for work so I can't send the discs away for any length of time but a day or so would be grand.
Does anyone have spare discs i could throw on just to test?
I'm just after ideas or options. I would like to keep the cost down because its cost me a shed load already.
