Help wanted
Darren Crump
Active member
Hi how's it going
Anybody around limerick have a boost solenoid I could use to see if mine one is faulty jumping up and down from one bar to 1.5
Try give it a clean too, could be clogged up with gunk and shite. I've none spare I'm afraid...and don't have my car at the moment either.
Bypass it and plumb direct to the wastegate with some vacuum hose and see how you get on first.
If you've steady wastegate boost try clean out the solenoid by spraying WD40 through the ports while alternating a 12v current manually to the solenoid.
Hi Darren.
I have one here you can try. or if you want to try the one thats in my car, there easy swop out.
What part of limerick are you in ?
I'm passing through Lmk Tuesday and Wed morning around 9 ish if its any good to you.
I'm in lisnagry near castleconnell
Will be working at that time u could leave it in the letter box if that's suits
