I've got a couple of timing belts done always stuck with dayco never a issueGetting my timing belt and water pump replaced shortly on my 2.5 Hawkeye STI and was thinking of going down the route of using a kevlar belt. Anyone use them and where did they purchase them.
Thanks Ross.
Appreciate that thanksI've got a couple of timing belts done always stuck with dayco never a issue
ntn and koyo idlers and ashin water pump there's a place in Poland subarurak sells them without charges. stick with intended stuff that subaru used less hassle belts aren't known for snapping idlers do go bad as some places say there good for another bit but no point in doing part of it I see you have Tommys hawk he would have looked after it well previously good to see it back in the club welcome
Went with the Dayco kit and Aisin pump. Thanks for the advice Gary and keadeen
They (any teflon coated / lined belts) are supposed to wear less and hence last longer.Any advantage to the dayco teflon lined belts ? Also this seems good value compared to other online prices
