Hi All,
I have V4 Type R 2.1 stroker, 550 injectors.
So I have a 3" turbo back exhaust - no cats. Each year for the test I swap it from the turbo back for a full std wrx system. Pass emission's no problem.
I was sick of swapping systems, so I dropped it into a place that makes exhausts and had a swappable cat made up on flanges for my 3" system. However it was failing on the lambda.
He suggested putting the mid section standard exhaust on from the cat. He removed the standard 2nd cat from the standard system. Still failing on the lamba, reading 1.09 , read 1.06 on a full 3 inch system. No exhaust leaks either.
So either I stick on the std downpipe , hopefully the new system is upto the job and passes before, basically a big waste of money.
Or my actual lamda sensor is gone bad. It has a bosch sensor I think. I looked up genuine sensors and there all in the region of 250-300 sterling. I can't see any bosch sensors listed online. I think I paid in the region of €100 for it 3/4 years ago.
Whats the opinions? Do I need the downpipe cat to pass?
Ideally I would like to get the swappable cat system working, as that was whole point. I was speaking to my mapper, he said he might be able to tweak it as the lamda should be reading 1.00 regardless.
