Large box/crate to UK
KENC
Lads want to send an item over to the UK, to protect it I've made a wooden box, it measures 1.4m long 0.5m high 0.5m wide..
The length is slightly over the 1.2m of a pallet, so seems to push it to 2 pallet space ffs, probably only weighs 100-150kg.. any ideas on what way to do it or who to use
Can you shorten the box and angle the item inside from bottom of one corner to the "top" of the far corner? It'll be taller but will fit the single pallet?
This might help you. Quote is based on delivery to London but could be cheaper if your destination is closer.
If you are sending an engine or gearbox there is a seperate option for this on their website
Website is called http://www.ukpalletdelivery.co.uk
No I can't shorten it anything
