Mapping around Cork
garry2682
Just wondering who do lads recommend to use to map a car around the Cork area. Ive a standard v4 sti type r and wont to have it mapped for irish fuel- not looking for any performance upgrades.
What should a fellas be expecting to pay?
Afaik garry there isn't anyone down that neck of the country mapping you should get in contact with dave Legacy rsr on here he uses Duncan Graham a top UK mapper dave is in Dublin or you could contact aonghus Based in Galway a good feeling lads here have used him, also your car is a version 4 what ecu have you if it's a standard ecu you will need either an esl setup or an aftermarket ecu
I have same car , if ecu says 7s on it its not mappable so you have to go aftermarket ecu route as Gordon said, simtek, Alcatek or esl
Dave @rsr automotive , trader on here supplies the above and can arrange mapping etc
jdm garage off the tramore road should be able to sort ya out....check out there facebook page....
I'm looking for good mapper around Cork.
Lads have u any contact number to Aonghus?
Thanks in advance [emoji6]
No worries just bear in mind he's usually flat out you might have a wait.
Definitely worth it though.
