Nct emissions
jayo
I had my legacy in for nct tonight and it failed on emissions .(gt peaders / big p's old car) it has 2.1 version 4 sti engine. Has cat in place (unsure of condition of it)
Any tips on how to get the emissions down?
It got a good spin down and was nice and hot.
Sent from my SM-G950F using Tapatalk
I can't help you with advice but this question do pop up often enough. Did you try the forum search engine?
Yeah I done a good bit of searching, but alot of them seem to have high idle issues only.
Some people get away with bung,diptane (drive off boost when it's in tank) just seeing if there is any other magic tricks before I go spending money unnecessarily
Car needs octane booster for hi boost,would octane booster help with emissions for test?
Nope... Octane booster wouldn't make a difference.
Seeing that both high/low emissions are off... but lambda ok... would say sensor ok and exhaust ok (no leak causing false reading)... so 99% sure it is the cat that is shot. Happened to my sports cat too... put the original cat on and passed with a huge margin.
Cheers mate,I'll start there.appreciate it
Hi mate I had the same prob with my 03 jdm legacy it turned out to be a pcv valve (positive crank ventilation valve) after swapping cats and 02 sensors the lot
Sent from my EML-L09 using Tapatalk
Get in touch with Peadar. Are you sure cat is in place? Last time Peadar had it for NCT it failed for same issue and I offered him my cat to go through NCT.
Cat in place, peader and big p had same issues from searching forum hopefully get it sorted and get to few meets with it .cracking car to drive!should have bought a Subaru years ago
New cat sorted out the issue
