J johnjoe64 Petrolheads Jul 15, 2014 #1 Hi Folks nct fail back plates at front brakes now where do I get these also I have Godspeed big discs on front and how much hassle to replace thanks.
OP OP J johnjoe64 Petrolheads Jul 15, 2014 #3 If I remove them will that not constitute a fail as they pointed the fault out to me.Cheers.
scoobysub Well-known member ISDC Club Member Jul 15, 2014 #4 Did they fail you for then being rusty or for not having any at all . I.v none on mine either and never had a problem
Grahamo spec c Well-known member Jul 15, 2014 #5 Yours must be holed or rusting away. I'd remove and chance again, cheaper than buying new ones. It's like a rear wiper not working, remove wiper arm and pass! If it's there it must work or be in good condition.
OP OP J johnjoe64 Petrolheads Jul 16, 2014 #6 Yeah its a rust issue I will get Dec to wip them of when he gets back from Oz cheers lads.
R Rob Spec C Octane Boostaholics Jul 16, 2014 #7 Even if the fail you again now for not having them, it might be cheaper to retest it from scratch rather than buying and fitting new ones.
E Evobully Petrolheads Jul 16, 2014 #8 I took mine off when I did the big brake conversion and she passed no bother.
