NF booster measurement bottles
Altezza-Dan
Anyone ever bother gettting some small application bottles or that for properly measuring out NF, Im also wondering how much i should be use to say bring 95 to 98 for an 80L tank? anyone know any handy ways to figure it out?
I have lots of 60ml syringes here. Actually that sounds bad....! There for my young lads tube feeding! I swear.... But anyway I can post a few to anyone that needs a few.... I use them for changing brake fluid too!
That's the ones
The rubber seal gives up after a while but a good pharmacy should have them
I used to use a third of a bottle so split my full bottle into 3 separate NF bottles. That way you can do it by weight so be accurate enough and when you go to fill up just throw the entire one third bottle in, save the bottle and reuse it again next time you split a full bottle.
just buy a jug next time shopping with a measurement on it
and pour correct ammount in to a already empty bottle
and repeat as the more bottles you have empty
that be easiest
every time a buy a syringe,
the pharmacist asks me million questions and looks at me like I'm the biggest junky in Ireland :D
mappers used to recommend half bottle of NF for subaru (45 litre tank?) so imagine if you were filling from empty on the auditank you would be using the best part of full bottle?
Depends what the car was mapped for Ciaran
If car was mapped for no booster I'd be still putting 50ml in just to be safe
I'm also a strong believer in some sort of knock sensor other than the factory one
Yea not mapped for it only for 95 so yup just to make it safer always have a bottle in boot in case I've to go to a station I'm unsure about but quality of fuel across the board is really bad so going to put 50ml in each tank from now on ????
Just got thease
