No abs ??? Help !!!
Superhigh90
Hi guys can someone advise . Yep got myself a Sti for ditch money . It's honest but not mint by no means .. Any how I've just tested the brakes and NO ABS wtf ??? Could it be a fuse ?
It's a gc8 Sti 1995 .
:hammerhead:
Is it a type r or ra? Does it have an adjustable diff, would have the roller next to the handbrake? If yes then you definitely don't have abs
Thanks for d replys guys , yep it has a pump and abs but not working ?? All fuses ok
Any ideas?? No it's not got diff control its Sti ., light weight bonett all right . Hoping for mondello on bank holiday weekend :comp26:
If you have a stretched or broken sensor cable at any wheel it will do that aswell
[quote author=Hammie link=topic=34148.msg393106#msg393106 date=1335992162]
Is the abs light on?
Hey thanks for the reply . No abs light on ?? Really confused
[quote author=KENC link=topic=34148.msg393243#msg393243 date=1336077067]
If I put a meter across the sensor what should it read ?? Anyone
