Yep its that time again where i go away and check to see what oil is most commonly used in a scooby.
In my opinion this greatly depends on the type of impreza and the way you drive it, oh and probably the time of year.
I live 3 miles from work, therefore i won't need the thickest mother of all oils as used in highly modded cars, also mine is a bog standard 01 wrx (irish).
sooooo....with all the conflicing threads, documentation and know all motor factors which oil should i use???
Mobil 1 10W 40 or Castrol 10W 60
