So the classic has developed an overheating issue.
Basically after driving for 10min + the temperature starts to creep and all heating is lost.
Almost like an air leak/water leak. Where no water makes it to the matrix.
New stat and new coolant recently enough. I'm not convinced on head gasket issues, rather maybe a rad issue or perhaps a leak appearing when the system pressures up.
Also a 1.3 bar cap is being used, could this possibly could highlight any weak areas? Should I stick the standard .9 cap back on?
Once the car is left to cool off the heating comes back.
Any common issues to look out for in the coolant system?
